HI,
Is it a possibility that RGBW relays will be included into the sprinkler panel ? as here in Australia with our dry climate irrigation is a big part of integration with smart homes :)
Also a calendar month option and longer running times than 15 minutes would also benefit.
Edited by D2ELEC
Hi @D2ELEC,
No, it is not possible, since RGBW behaves as Dimmer. I would go with Z-Water (
since it has 10 relays and i do not think that sprinkler needs more than 5A.
Jakub
    Thanks @jakub.jezek
    unfortunately i require a relay controlled by 12v DC only hence why I'm using the rgbw from Fibaro :) I do understand what you mean with the dimming capabilities and why it can't be used in the panel.
    i guess I'm just hoping @FIBARO might have a solution in the near future !
    @D2ELEC, you can add 12V for Input into channels. 100-250V is only power for module not for Outputs. What you connect to relay in Z-Water, then when it switch, you will receive it in output. Yes, it has limit for DC (30V DC max.), so 12V is perfectly in limitation.
    If you need something, that is even powered by 12V, i have some experience with Z-DIN616 by Heatit (
    . It has 6 Outs and it have (atleast EU version) 16A relays, so it handles everything. BTW relays are NO.
    Also, i do think, that in Fibaro, they will tell you to use Smart implants, to get 12V DC switching capabilities.
    Jakub
    @jakub.jezek I am definitely restricted to a 12v DC power supply.  Do you know if the Z-DIN616 is available in Australia ? Have you ever controlled one with the HC2 ?
    thanks,
    D2ELEC
    I do not know. Try to contact Thermofloor
    Yes. Even with HCL. Just after inclusion i suggest to let it "settle in". 10 - 20 minutes should be enough.
    Ok so I have used a single switch relay installed in the property and grouped it with the RGBW which now acts as a dummy relay and allows me to see it in the sprinkler panel :)
    Sorted !
    Would still like to see a monthly timing schedule in the sprinkler panel @FIBARO
