Use JSON for variables
Hi all,
Based on the following idea i was checking out the possibilities for my HC2:
I created several variables and notifications which should send pushover messages when the basic variable is changed from None to the kind of Garbage.
Now i'd like to create a LUA script to check the current date which can be checked in the output of my JSON file, if there is any kind of Garbage today.
Output is like:
[{"afvalstroom_id":138,"ophaaldatum":"2018-01-02","timestamp":1514847600},{"afvalstroom_id":132,"ophaaldatum":"2018-01-05","timestamp":1515106800}]
In this case my ophaaldatum is the date to check (current date == ophaaldatum), and if these date are the same my predefined variable must be changed to example:
138 = GFT
132 = PMD
In this case is the situation when today is 2018-01-02 i'll want a pushover message that i have to remember the GFT garbage.
Please help me out, how can i check the JSON file (which is located
) and translate it to change my predefined variable?
13 answers to this question
Guest Turmoil
Quote
I assume you are using something similar to
for both pushover and access to the afvalkalender. The Lua script there decodes the received json with
I have not used this further myself but my understanding is that 'result' in this case is a Lua table structure built from the received data. You can see the mapping relationship in a problem of a different sort reported on
. From the Lua table you should be able to make simple comparisons as required.
I'm new at this myself so I may be barking up the wrong tree but I hope it gives a starter for getting what you wanted.
Guest Turmoil
I had a bit more time today and could not stop from experimenting. You should be able to use something like the following:
You'll have to finish the testing for garbage collection info, from what I received you will get an array of collection dates etc but that may be what you are requesting. You will also need to put your pushover data into the request.
    Ahh thats great, i will test it asap and ill let you know!
    i'm checking right now, but on which way you checked the date? because there is no time definition? it gives me correct the message, that there is no message to send but it might be that it doesn't check the correct date in my opinion..
    Edited by Harmen070
    Guest Turmoil
    Hi, I see now that I overlooked that your response.data is actually as follows (1st 4 rows only .. and yes you had shown this initially):
    You may want other tests etc but I think this works in principal. The difficulty is the use of the two dimensional array-table structure.
    Good Luck!
    Edited by Turmoil
    Hi @Turmoil , @Harmen070 ,
    I like the idea!
    After playing a while with the code i managed to get it work. ( @Turmoil , credits to you for providing the code, great work!)
    instead of displaying text, I think I will use an icon which change color orange, green or blue when I have to get the bin out.
    I use the HVC URL and it uses other "afvalstroom_id's" but that shouldn't be difficult to change back to the Avalex URL.
    Edit: Added the information below to keep the information together,
             For most of the part the text is a shameless copy of the original post at
    This script is for Dutch users, that must place their containers on the street.
    Start your browser and go to https://apps.hvcgroep.nl/rest/adressen/zipcode–housenumber
    replace the red things with your info. for the url you can use the url of your collector:
    Collector's:
    Cyclus NV:
    HVC:
    Dar:
    Afvalvrij / Circulus-Berkel:
    Meerlanden:
    Cure:
    Avalex:
    RMN:
    Venray:
    Den Haag:
    Berkelland:
    Alphen aan den Rijn:
    Waalre:
    ZRD:
    Spaarnelanden:
    Montfoort:
    GAD:
    Cranendonck:
    The output you get looks like this:
     [{"bagId":"0505200000092263","postcode":"3328LN","huisnummer":35,"huisletter":"","huisnummerToevoeging":"","openbareRuimteNaam":"Moestuin","woonplaatsNaam":"Dordrecht","latitude":51.7701971,"longitude":4.6597255,"woonplaatsId":2351,"gemeenteId":505}]
    Write down your bagId number! that is the unique key of your address.
    The BagID is used in the following URL's:
    Ophaaldagen:
    <<replace BagID
    In the output you see "afvalstromen" ID's.
    Use this URL to find information about your ID's:
    <<replace BagID
    Adjust your settings in the script: BagId, afvalstromen ID's and collector url. (I only have tested HVC)
    Edit: 1-10-2018 new version: changed "zoekdatum" to tomorrow. (I like to have a notification the day before) and changed notification text a bit.
    greets,
    Remi
    Edited by Remi
    Thanks, I might have a use for this with my TTS scenes!
    Jim
    I’m testing at the moment but when i’m done i will share the code
    Can anyone just help me how to schedule this check? i'd like to run this script twice a day, but i doesn't see any option how to schedule this check
    When I don't know how to do something I begin with a block scene, and convert it to Lua.
    And copy the code i want to use.
    Example:
    Question:
    In the script we check for the current date, and that's the easy part since the current date is known.
    Part of the code:
    Edited by Remi
    Assumes that the result table is sorted on dates. The last date will not get a days2next field.
    result =
    [{"afvalstroom_id":5,"ophaaldatum":"2018-08-02","days2next":14},{"afvalstroom_id":5,"ophaaldatum":"2018-08-16","days2next":1},{"afvalstroom_id":6,"ophaaldatum":"2018-08-17","days2next":7},{"afvalstroom_id":3,"ophaaldatum":"2018-08-24","days2next":6},{"afvalstroom_id":5,"ophaaldatum":"2018-08-30","days2next":14},{"afvalstroom_id":5,"ophaaldatum":"2018-09-13","days2next":1},{"afvalstroom_id":6,"ophaaldatum":"2018-09-14","days2next":7},{"afvalstroom_id":3,"ophaaldatum":"2018-09-21","days2next":6},{"afvalstroom_id":5,"ophaaldatum":"2018-09-27","days2next":14},{"afvalstroom_id":5,"ophaaldatum":"2018-10-11","days2next":1},{"afvalstroom_id":6,"ophaaldatum":"2018-10-12","days2next":7},{"afvalstroom_id":3,"ophaaldatum":"2018-10-19","days2next":6},{"afvalstroom_id":5,"ophaaldatum":"2018-10-25","days2next":14},{"afvalstroom_id":5,"ophaaldatum":"2018-11-08","days2next":1},{"afvalstroom_id":6,"ophaaldatum":"2018-11-09","days2next":7},{"afvalstroom_id":3,"ophaaldatum":"2018-11-16","days2next":6},{"afvalstroom_id":5,"ophaaldatum":"2018-11-22","days2next":14},{"afvalstroom_id":5,"ophaaldatum":"2018-12-06","days2next":1},{"afvalstroom_id":6,"ophaaldatum":"2018-12-07","days2next":7},{"afvalstroom_id":3,"ophaaldatum":"2018-12-14","days2next":6},{"afvalstroom_id":5,"ophaaldatum":"2018-12-20"}]
    Awesome it is working perfect for me, thank you all guys!
