Yolo 0
Hello seniors and comrades,
i have a virtual device for iEast stream pro and i would like to Use the Playlist Function buttons to play Music in my Scenes but i have no idea how to do it.
i don't know how to make and add music in the playlists. i can only play through USB Button function.
i have tried searches but nothing, and this forum is my only hope i got.
Lua Code in the Playlists:
-- Play Preset #1
local command = "/httpapi.asp?command=MCUKeyShortClick:1";
local selfId = fibaro:getSelfId();
local ip = fibaro:get(selfId, 'IPAddress');
local port = fibaro:get(selfId, 'TCPPort');
local connection = Net.FHttp(ip, port);
connection:GET(command)
fibaro:call(selfId, "setProperty", "ui.labelState.value", "[preset 1]");
See the attached is my VD for iEast Stream Pro
Looking forward for your kindness and help.
Thank you all.
