Spindel 3
In an attempt to tidy up in my HC2 I would like to rename some of my global variables.
However. I have quite a few scenes depending on global variables so I´m wondering if changing the name in the Variable panel also will update the name in all scenes using that variable? I use both LUA and block-scenes.
Hmm... It seems you can´t rename a global variable. Is there a way to track which scenes use variable x?
