Scene history/log
Is there a way to see when different scenes have been run? Like the events-page for devices.
15 answers to this question
http://192.168.1.36/api/virtualDevices/560/debugMessages
192.168.1.36 - HC2 IP address
    Is there a way to do this whilst being away from home?
    you could write a script which is activated by the scene and debugs the scene that is being ran. Something like:
    Edited by eureka
    IMHO no,
    @eureka he wants to control VD not scene
    ha! I am wrong! You OK
    sorry!
    Edited by 10der
    That´s above my skills, I think.
    Also, wouldn´t I have to do this in all scenes separately and also convert all block scenes to include it? I want to have an overview of all scenes. When they start etc.
    you could just add the sceneID of your blockscenes to the sceneActivation part. So you would only have 1 scene with all the info on when something started.
    If I modify your script to include all my scenes, can I use wildcards?
    For example:
    And
    Also
    Where and how can I see the result, lets say after a few days?
    For example:
    And
    Also
    Don't think that works. everything between %% needs to be  'hardcopied'
    so you need to add every seen that you want to monitor in there.
    The getSourceTrigger will then show which of the scenes was used to trigger the code. It will show in the debug window below
    Ok, like this?
    yes, that would work:
    this would also work:
    Are you sure it´s supposed to be "deviceID"?
    [DEBUG] 09:25:08: [1;31m2018-10-08 09:25:08.660203 [ fatal] Unknown exception: /opt/fibaro/scenes/129.lua:74: attempt to concatenate field 'deviceID' (a nil value)
    /monthly_2018_10/image.png.f5db686ce537a2f382ebd258eb8893f1.png" alt="image.png.f5db686ce537a2f382ebd258eb8893f1.png" />
    can you put the following code in:
    and see what it spits out?
    deviceID might indeed be the issue as its a scenario trigger, don't know if it is sceneID instead of deviceID. You can try that as well?
    /monthly_2018_10/image.png.26cb578246e0cb16990f5a7dbba08464.png" alt="image.png.26cb578246e0cb16990f5a7dbba08464.png" />
    sceneID or deviceID gives the same result, this is when I manually start the script so perhaps that´s the issue in my pictures.
    However, I think it also fails to run when any of the triggers/scenes are run, I can at least not see any activity in the debug window below after I´ve started some scenes manually.
    you should indeed not manually start, deviceid will be empty then..
    you should trigger one of the scripts that you follow and then see what the output is.
    Then output is nothing. It´s just black, no errors or other text.
