eureka 9
Hi All,
Can't post in Crowd Solutions, so thought this would be the second best place to go.
I've been working on a solution for the issue with not getting notified when you have a dead node in your system. Currently I'm having issues with this so I wrote a script that sends an e-mail if you have a dead node.
it can also try to wake the node, if it then goes dead again it will not try to wake it again (as it is actually dead). You can choose to always get an email notification, or to only receive an e-mail notification if there are new nodes that have gone dead.
Please note that, if you choose to wake nodes, you should not run the script every minute, as it can seriously affect your system and cause freezes of 10 to 20 seconds. Personally I use @Sankotronic Time Scene Manager which runs it every 6 hours.
Special thanks to @petergebruers who helped create and tweak the script.
EDIT: Seems like layout gets a bit scrambled on the forum, added a txt with the code as well
Edited by eurekaedited the code, past was missing
12 answers to this question
