  • 2
Local vs remote
MDC
I just install the device and i still have some questions.
1. In advertising it's show a dude on a boat connected to his intercom app from where he can check all his intercom videos and logs.
@MDC , thank you for sharing your view on the subject.
1. The image will be changed as it may confuse a user. You are right, video history is not available in 3/4G. App does not offer export tool for videos.
2. It is possible. You can use QNAP or Synology. Use port 80 and the stream is /live/mjpeg
3. This is another mistake on the website. The Intercom does not provide such option as a standalone device. But you can achieve it with LUA using FIBARO system. The content on the website will be edited to be more clear.
I apologize for the inconvenience.
    Thanks for clarification.
    One other thing that I noticed is about videogate from fibaro app.
    If you are outside network you are unable to see preview. In local networks works!
    ADMIN'S NOTE: Please, follow the guide when adding images to your posts.
    Edited by T.Konopka
    https://forum.fibaro.com/topic/30009-how-to-properly-attach-images-and-clips-to-your-posts/
    @T.Konopka Can you share the LUA code? Or where I can find it?
    Best Regards
    Edited by rovrell
