[Solved] "Assertion failed" error in VD, what have I done wrong?
I have created the following variables, where I want the values from a json string to be stored:
"uRad_ch2o", "uRad_co2", "Rad_cpm", "uRad_humidity", "uRad_noise", "uRad_pm25", "uRad_pressure", "uRad_temperature" and "uRad_voc"
Main code in VD.
From the debug window I get:
I am a bit lost after trying multible code solutions...
Edited by Teza
Solved
without call function only:
local temperature = jsonTable.data.temperature
or direct:
fibaro:setGlobal("uRad_temperature", jsonTable.data.temperature)
test example:
result:
Edited by drboss
    Thank you very much!
    Finally I am a huge step forward on this VD.
