LUA code to find my hue id
Hi, im very new to this so forgive me for my stupid question.........I have a Fibaro HC2 and would like to integrate a few of my Philips hue lights , to do this i need my hue id which im having trouble getting, ive searched the net everywhere but still cant understand how to make this work, Can any one help, Im desperate.
Also any suggestion on best way to integrate my current standard dimmable leds with fibaro hc2 is it just the Fibaro Dimmer 2 that can do this i just want to turn on/off and dimm.
Appreciate your help.
Mark
Hi @Mark meli,
you coul'd start reading the posting of @Sankotronic , which is a complete tutorial for Philips HUE.
Success with your integration :-)
    Hi as you can see from the picture below, the instructions in the link provided  seems like its off an old version of the hue app, im running version 3.6.0 (10083) and cant seem to locate this info ? Are there any other options i can try , every other step has worked so far?
    Also need some advice with below,
    below is exactly what i cut and pasted into each slider and main loop , is this correct or do i need open and closed brackets
    "username": "y1ipzzCIxneobbAoEIeOn-M3Qj9J06cT7zUXpaPR"
    Hi @Mark meli,
    the current app version is 3.6.1 btw, but never mind the version. Go to settings -> About and you will see the bulb ID's see below:
    In your VD you just enter your retrieved user name "y1ipzzCIxneobbAoEIeOn-M3Qj9J06cT7zUXpaPR"
    Edited by Bodyart
