Hello together,
I'm thinking about buying a Shop Vac  cleaner, but already have a good regular vacuum cleaner.
What advantages has this cleaner in comparison to a normal one?
Normal one sucks (literally) :-D
We have one form craftsman and I would not give it for anything else. We use it for our garage, our terrace and to vacuum the cars. If you vacuum a lot outside, I would recommend you a a vacuum cleaner with large containers. Our holds about 30 liters, which is quite nest.... As a surf tip, I can recommend you the page
 . We had read a bit before buying ours and found some really good tips
