Automation bridge - No connection
datathomas
I have a customer that has installed an Automation bridge from Skaro. It worked fine for sometime but all of a sudden he started to receive e-mails from his HC2 that the bridge IP had 5 failed login attempts and was blocked.
Logging in to the bridge we can see that it does not connect to the HC2. The password is pretty long so changed it the the HC2 to a very simple one but the bridge does not log in anyway
The bridge is using the Superuser account to log in.
Anyone have a clue?
Is there a way to see a log of failed logins and maybe reasons for the failure in the HC2?
This same thing just happened to me. There was a post around 2018/9 saying to set the local name and password to the Fibaro ID one. I have done so but that hasn't helped my case.
