I use LUA scene with event trigger
%% autostart
%% properties
%% events
340 AccessControlEvent
%% globals
This works well and is very useful, thanks.
As start source at
I get this table:
{"type":"event","event":{"data":{"name":"Martin RFID","description":"ZTX_ACCESS_CONTROL_EVENT_KEYPAD_UNLOCK_OPERATION","type":"Keypad","status":"Unlock","slotId":2,"id":340},"type":"AccessControlEvent"}}
But there is not information about eventide, which started this scene instance. This is necessary to check, if this scene instance is last, when more instances were started at same time, eg. at group actions, arming or disarming.
Is possible to add this information – eventID, to start source trigger information? On best with timestamp event information.
At system events is this information included.
{"id":8188583,"type":"DEVICE_EVENT","timestamp":1538650961,"deviceID":340,"deviceType":"com.fibaro.doorLock","event":{"type":"AccessControlEvent","data":{"id":340,"type":"Keypad","status":"Unlock","description":"ZTX_ACCESS_CONTROL_EVENT_KEYPAD_UNLOCK_OPERATION","name":"Martin RFID","slotId":2}}},
Thank you very much.
