I am running Fibaro in my boat. The boat does only have 24VDC  and no 230VAC .
What I am looking for is a simple switch that can let me turn ON/OFF a 24 volt motor from home .  I have been looking at the Simple/double Switch and FGS-212 but the manual says they both run on 230VAC and NOT 24DC.
Do fibaro have any switches that can run on 24VDC and that is not a dimmer ?
you can wait for the fibaro implant to activate a relais for youre 24vdc motor.
  • 4 weeks later...
It is not documented, but Relay Switch (FGS212 and FGS222) works powered by 12/24VDC. Latest FGS213 and FGS223 not.
@Albert are you sure? i never heard about that
Did you test this?
Edited by akatar
It i mentioned for example in latest documentation from Fibaro, how to integrate Nice gate controllers with Fibaro system, via FGS222.
Officially it is not mentioned in spec, due to certifications, i guess.
But personally I did not tried it myself.
i know that the 2x1,5 switch (first version) can switch anything, but as far as i know it runs on 230vac.
perhaps someone knows if it's posseble
