Loop scene advice
Hi all, is there a way to have this scene running automatically?
I want to start it, and then it should start and run for 6 hours every time the temperature is less than 22 degrees.
Now I start it, and it runs for 6 hours, when temp is below 22, the scene does not "restart"
/monthly_2018_10/image.png.a619a9073e2347aeb74cc8d2f0b32fce.png" alt="image.png.a619a9073e2347aeb74cc8d2f0b32fce.png" />
5 answers to this question
Imho you should create time based block with all you required parameters as AND op
    @10der Thank you for the reply, but I do not understand what you suggest.
    I tried to change the "then" to "and", if that's what you think, but it will not take that change.
    Logically I can't understand why my scene does not work, to me it all makes "logical" sense :-)  (IF THIS THEN THAT).
    @Soft I am not "guru" in visual block building. but OK waiting.
    IMHO
    1) check everytime ( 60*1000 )
    2) if wind speed > 10 m/s
    3) turn on my RGB LED strip and play Storm program
    for turning OFF create another block with inversion checking and TunOff command
    PS: btw, do you know what your task can be solved with building in HC2 features.
    1) /fibaro/en/panels/temperature.html
    2) /fibaro/en/connections/edit.html?type=heating&id=0
    Edited by 10der
    I agree on the Heating panel.
    The problem is that I can't select the on/off device in linking devices:
    /monthly_2018_10/image.png.8e408b3abd0e0cbca9bc0cb21be715fd.png" alt="image.png.8e408b3abd0e0cbca9bc0cb21be715fd.png" />
    I can select the temp sensor fine, but not link it with the heatit controller:
    Ahh, Ok, sorry
