bbennetts 0
Hi all,
I am hoping to get a little clarification.
Firstly: I have a two wire (i.e. no neutral) light circuit with non-dimmable LEDs. Could anyone confirm whether the Dimmer 2 will work in this scenario - the manual says (my emphasis);
But I am assuming this means when in a 3 wire (with neutral) circuit? In which case I would need to replace my bulbs.
Secondly: When using a toggle switch with the Dimmer 2, again with a 2 wire circuit, does toggling the switch to 'off' unpower the Dimmer module, or is the Dimmer constantly alive and it just monitors the switch for toggling? I.E. if someone turns the switch of will I still be able to turns the lights on/off via the network?
TIA.
