HC2 will not connect to internet
Guest Tornado
I have had some problems with my router, after changing it the HC2 will not connect to the internet again. It is only light in the two first LED's from right, not the third LED. I then are not able to get in contact with it from Fibaro Finder either.
Tried with factory reset but I still don't get connected with my PC.
Is it broke or some other solutions?
Did you figure out of this issue? I have the same problem after upgrade to latest firmware update. HC2 was working just fine until the update...grrr
