I have a Qubino Smart Meter but device has no template. I open a ticket to the support 2 years ago and until now nobody knows when il will be available for the users. I can use the device but how long is the creation of a so old device?
4 answers to this question
Device does not work? It should be working ok without a template if it is Z-Wave Compliant.
Template only adds parameters which you can add manually if needed :)
    Device it work the point is that there is no way to undestand the meaning of the parameters and there is no way to add the device in scenario (very bad). The point is that the support promises to release the template and after one years there is no news about it
    If you knows device parameters you can always add it manually.
    yes, it’s not comfortable but it’s works.
    there is something odd with Fibaro and Qubino... they stopped supporting all the GEN5 devices so it seems, even only old dimmers are supported with parameters I think..
