Transfer configuration from a HC2 to another HC2
Hi !
Has anyone used this Feature in Fibaro Remote Access before ?
Is it really that simple ?
Are all Z-Wave Devices transfered with original ID ? Scenes are working ?
I am a bit afraid of trying this.
yes it is, but you have to have on both 4.511 installed. Create as well on both cloud backups, to double check if backup is working.
Having backup of your source HC2, you have not to care about, even if migration fails, all the data can be restored by Fibaro Support.
    Now i have 2 not working home centers...great. I DO NOT RECOMMEND using this Feature !
    Tried to recover from file, but this is corrupted, how do i recover from cloud backup ?
    Edited by Fireblade900rr
    did you made backups as i told you?
    did you interrupted the process? (reading "tried to recovery" probably you did it)
    When you followed my advice, no reason to worry about, Fibaro Support can restore it within minutes
