Fibaro Relay - VD to show up on Fibaro App?
Hello, just wanted to see if someone can help me. I've got a few relay's setup to control gates/doors and I need to be able to access them in the iPhone App - however it seems there is no function to access the relays directly... So I was thinking what is the easiest method to get them shown up on the app under Blinds or Equipment menu area?
Would a VD of the relay work and if so can someone explain how to do it.
Hi there,
a fibaro relay  should be visible in the Iphone app.  Maybe you made the relay hidden in the  web interface ?
     I've been through every screen and sub menu in the app but nothing shows the relay. I can see the device under the "room" menu but it has no options to toggle/on/off.
    On the controller its not hidden or marked as anything.
    what version of the fibaro relay you are using ?   please post a screenshut of the device you see onder the room menu
    Edited by fkruis
