FIBARO Compatibility is a convenient Internet platform, where you can find a list of devices compatible with the FIBARO smart home system. Preparation of a list of supported devices is a tribute to those who think about a smart home in a comprehensive way, want to compose their own system and try to expand it with products of other brands, which are supported by FIBARO and can be easily added to the smart home system.
The FIBARO Compatibility database contains 1286 devices of 266 brands from all over the world, and their number is still growing. Such a complete list allows to find almost every type of device, which may be of interest to the inhabitant of an smart home. The platform has been equipped with special filters, which will allow you to quickly find the items you are interested in: device type, brand, communication standard and compatibility level. Thanks to the use of such filters, we will be able to check whether, for example, the door control unit can be connected to the FIBARO Home Center without facing any obstacles.  Compatibility list is also an excellent solution for installers and architects, who, at the planning level, can compose the right system for the customer, while ensuring that the entire environment will function well.
