I have a EZVIZ Camera CS-CV310 and I wonder how I can add it to the HC2 as there is no plugin for that camera.
Any thoughts?
  • 4 weeks later...
I can see that EZVIZ cameras are not mentioned at all on
You can try to add it as device (not plugin) but you will have to find out what is camera IP address and TCP port, what is path for picture and stream and if your camera supports MJPEG stream.
  • 1 year later...
Hello
I bought yesterday an Ezviz camera C6N but the same problem : I can’t manage to integrate it into my Fibaro HC2
did you manage ?
great thx
1 hour ago, JCJC said:
Hello
did you manage ?
great thx
you will be not able to add (any) Ezviz cams into HC2 directly, they can only stream to cloud (not mjpeg stream), mmc card (local data) or recorder (rtsp actually, so you could stream that to android device with tiny cam pro installed to convert to mjpeg to get displayd in HC2 - search forum for how to). Ezviz user for rtsp is admin, password is the pin on cam enclosure.
