So, this is some code that can be pasted in at the beginning of a scene (before first fibaro:getSourceTrigger()) and it will log all  fibaro:* calls, e.g. fibaro:call(...), fibaro:sleep(), fibaro:getSourceTrigger() etc. Quick way to get an understanding what is happening in a scene.
Also if you have a 'HomeTable' with device IDs, you can register it to get the device names instead of the number values in the log printout.
Just for debugging, remove when you have found your bugs...
Running gives the following output
Note, Fibaro implements fibaro:getValue with fibaro:get so it logs twice...
Possible to turn off tracing of set of commands with .debugFlags.*
Here is a one-liner version of the code
  • Thanks 2
