Led turn off after booting
I have recently upgrade, and after reboot HC2 stopped working.
I tried to boot, and this is what happends:
1- Leds start blinking normaly
2- Loading procces si normal with eds status changing
3 after all leds stop blinking they all fade off
- HC2 is off
I tried too  the same proccess for starting recovery mode, but the problem is the same. Ths video shows it:
Thx!!!
In my case the problem was with a jumper on the mainboard: J21 just fell off somehow, idk how.
Guest macjoker
I had the same issue. The LEDs were blinking in a right-to-left pattern during the boot process, simulating a progress bar. Once all LEDs stabilized, they faded off, and the device powered down.
I checked the power supply unit (PSU) with a multimeter, and the voltage appeared to be within the acceptable range. Despite this, I opted to replace the power supply, and to my surprise, everything is now working perfectly fine. The original PSU (12V, 4A) must have been corrupted to provide enough current: at first, the device started, but as soon as the current consumption was increased my HC2 died. I have replaced it with a little stronger unit (12V, 4.74A). See photos of both units below.
FYI Changing the power supply did the trick for me.
edit: spoke too fast, the power supply is ok, I connected another hc2 on it and it went fine.
Edited by sjauquet
Finally fixed by going into recovery mode and choosing the first option (repair or something like that)
On 11/30/2018 at 3:39 PM, marknuk said:
Take out the recovery USB drive, reboot,  and all will be good...
It worked for me as well, still I thin time to change to HC3. Its six year old now ...
not perfect, at least I could enter in the menu :) Tomorrow I change the adapter as well, I hope it will work...
I faced the same problem. Just changed battery CR2032. It helped.
Same here.
