I’ve three Flood sensors. I wasn’t any problem with them until I updated my devices to iOS and tvOS 12.x .
From when I ran the apple update first flood sensor became permanently unresponsive , second became randomly unresponsive, and third working normally.
If I restart the Flood sensor unresponsive removing battery it come back working for a bit of time and then return unresponsive.
From iOS home app, many information are read correctly (only battery % is missing) while  unresponsive error is occurring.
Are you aware of this problem with iOS 12.x?
Edited by Fraz76
  • 4 weeks later...
Hi @Fraz76!
Are you sure it's not a range-dependent issue?
Have you changed the location of your home hub?
Is the issue still there? Have you updated iOS 12 to the latest version, iOS 12.1?
