After attempt to update firmware, Heat controler blink cyan. it not responnd to any click on button, application cannot connect (apple homekit)
Hello @brouk111!
Thank you for your post.
Let's go through the viable troubleshooting together:
1) Have you used the latest and most up-to-date version of our
2) Have you "killed" the app, opened it again and tried to initiate recovery procedure on that device (make sure you are quite close)?
3) Have you updated the Heat Controller twice?
We have identified some issues with updates indicator, which shows up even when you are on the latest version. Please refrain from updating for now.
If your Heat Controller is still unresponsive, please contact FIBARO support to get to know more about warranty procedure.
