Hi everyone,
I am trying to send a push notification on my mobile through my Fibaro HC2. I want that whenever my virtual device is ON/OFF, HC2 sends a push notification on my mobile device. Even I tried that with Lua script, but I am stuck. If anybody has the idea how to do it, please help me out in this case.
Thanks in advance.
    Hello everyone,
    I have made some progress in the code. I am now able to push notifications through ON/OFF buttons when pressed manually. But I am still unable to run the code in the main loop. The code somehow starts running in the loop and the notifications keeps coming continuously. Here is the code.  Now can somebody please tell me where to put my code to trigger the notifications. I have created the variable and used the variable to trigger the notification and created a scene. Now I am triggering the scene whenever the virtual device turns ON/OFF. I am not sure where to enter the code to trigger the scene in the main loop.
    function updateStatus()
        local deviceID = fibaro:getSelfId();
        local ipaddress = fibaro:getValue(deviceID, "IPAddress");
        local port = fibaro:getValue(deviceID, "TCPPort");
        local rPi = Net.FHttp(ipaddress, port);
        local resp, status, result = rPi:GET("/cm?cmnd=status");
        local stat = "ERR";
          local icon = 6
        if ((result == 0) and (status == "200")) then
            local status = json.decode(resp)["Status"]["Power"]
            if (status == 1) then icon = 5 else icon = 1006 end
            if status == 1 then stat = "ON" else stat = "OFF" end
        else
            --fibaro:debug("Result = "..result)
            --fibaro:debug("Status = "..status)
          fibaro:call(deviceID, "setProperty", "currentIcon", icon);
        fibaro:call(deviceID, "setProperty", "ui.".."lblStatus"..".value", stat);
    updateStatus();
