simple garagedoor scene
I'm new in programming Homecenter 2 Lua code and so on but try to automate my house.
I have Novoferm garage door with a fibaro relays switch as pulse relays. When push the door relays the door will go open. next push door will stop next push door goes down. All works as a single button double action. When door is visible it works fine but when not, visible I like to be able to open the door and close the door. So, when I press close the door and it is closed that the door will not open
Therefore, I like to have is a scene door open and a scene door close. So, when door is closed (I can see with fibaro door switch) and start scene door open the door will open. When scene door close and door switch is open that the door is closed.
I tried to make with function blocks but don’t find the signal door close and door not closed so I can make if not stormy weather and door is closed the door will open.
Is there someone who can help me with this?
Thanks in advance
Wilfried Baars
4 answers to this question
idk. maybe like this
    Thanks for reply.
    I tried to import this virtual device but i think something wrong. I don't get a device with parameters as in pictures. and how do i use in this virtual device the fibaro doorswitch and door relais.
    Maybe stupped question but i hope you can help.
    Perhaps other information. it is also possible to open the garage door with standard remote. so open and close with standard remote but also in parallel with the fibaro relais as puls relais
    Purpose is to open the  garage door automatic if coming to the house with IFTTT scene. When in the house the standard remote is more easy that the app.
    Fibaro does not provide import/export icon.
    not clear here. do you have  fibaro doorswitch  or  fibaro relay?
    but if honest - no difference.
    I do not understand your question.
    I use fibaro window door sensor to detect open close of the door. And the fibaro doube relais FGS222 as contact in parallel in the door controlbox. With this relais i make a puls of 2 second to open or close the door.
    Maybe whatsapp is easy to send pictures?
