akatar 208
i did a complete toilet renovation and i decided to use a dimmer 2 for the lights, so there was no need to install the blue (neutral) wire.
when i install the dimmer 2 the lights flicker continuesly, even if the dimmer is off.
even the green led on the module itself goes on and off.
hc2 message: [19:24:58] ID 435: Voltage Drop/Drift. Reduce the maximum brightness level.
that is not correct, voltage is around 225 volt and when i connect the lights directly the lights are burining bright and steady.
someone any ideas? thoughts? anything?
29 answers to this question
