I would like to install the fibaro system inside my switches...
The system need to be HomeKit.
The problem is that I don't understend if the fibaro device can be used with my switch.
(I attached some photo of my switch system)
There is 3 switches who control 3 place.
- The kitchen
- The dining room
- the living
Switches for the kitchen and for the living can be controlled at 2 place.
The dining room can be controlled at 3 place.
So can I install the fibaro system compatible with HomeKit ? is it working with switches who are controlled at different places ?
here is some photos of the installation
Thanks for your answer ! I really hope it is possible !! :)
Check this wire diagram. For toggle wire system you need only 1st and last (toogle switch) w/o intermediate switch (kitcher and living room). With intermediate switches (in your example - you need only one intermediate switch with two toggle switches) adding to your dinning room...
Edited by ggrizliv
    Hi ggrizliv
    I thank you very much for your answer.
    it's the first time I'm working with electricity and I didn't understood well your answer.
    If I understand my system the switches from my photos are :
    Kitchen : 2-way switch
    Living-room : 2-way switch.
    Dining room : Intermediate switch
    So...
    - If I want my kitchen to be HomeKit I need to put the fibaro single switch on the first 2-way switch from my photo. way switch controls the kitchen)
    - If I want my living room to be HomeKit I need to put the fibaro single switch on the second 2way switch from my photo
    - but what can I do for the dining room ?
    Or maybe I didn't understand nothing and I just have to put just on fibaro switch for the kitchen AND the living room ?
    I'm really sorry not understanding well.
    Shervin
    It is definitely possible and I suggest to get someone who does understand how to wire the system. For multi switch wiring, you should be little bit more "skilled". And I do suggest to use momentary switches instead of  bistable. Than also wiring is little bit simpler.
