All Lichting Off, Controlled device with LUA
Hello ,here is my question
I have a LUA script that turs of all lichting ,but also the gardenlichting .can some someone tell me if I can use the Controlled device setting in the Lua script.
So that the script only turns off Lichting or other devices.
Thank's in advance.
Edited by Jaapkooi
8 answers to this question
  • 2
I read through
and I found a chance to optimize my setup :)
Here is the scene for you :)
The diverent deviceControlType are:
2  Lighting
5  Bedside Lamp
7  Wall lamp
11 Garden Lamp
23 Dimmer
Edited by PreHack
    On 10/29/2018 at 12:23 AM, PreHack said:
    I read through
    2  Lighting
    5  Bedside Lamp
    7  Wall lamp
    11 Garden Lamp
    23 Dimmer
    I can't thank you enough..
    I have been kikking the *abuse* out of this script , it realy great.
    2 Lichting
    3 garden sprinkler
    4 Pin    --?
    5 Night cabin licht
    6 Water heater
    7 wall lamp
    8  Airco
    9 Alarm detection
    10 Coffie machine
    11 garden licht
    12 TV   --
    13 Ceiling fan
    14 Breadtoster
    15 Raidio
    16 ?     (For dimmer only)Garage door
    17 Roof window
    18    ?   ( For dimmer only) roller shutter
    19    ? ( For dimmer only) Curtain
    20 different devise
    21 Alarm status in/out
    22 Alarm in
    23  Dimmer
    24 Intercon Bell
    25 Intercon Open
    Edited by Jaapkooi
    Irony
    you forgot to insert jpeg file with LUA into MS word and take picture again!
    PS: can to read tea leaves. Can find LUA errors by photo, can debug your LUA script with closed eyes ;)
    I use this one
    looks cleaner to me and for a modification you should look into this thread
    2 hours ago, 10der said:
    Irony
    Hi thank's for your time.
    This script works fine. but it turns of all lichting. That's not wat i want , i want to turn of only inside lichting not the garden lichting.
    Thats why i wonderd f you could turn of by (controlled device) every module can be set to something .In my case Tuinverlichting (Garden licht).
    With my script it wil turn everything that has a conection to lichting off.
    i only want to turn of Verlichting . Foto 2
    1 hour ago, PreHack said:
    I use this one
    Hi thank for your help
    It works good i want to modify it.
    # i will try your's
    # Your's also turns of everything what is associated with lichting included my satel alarm system. :)
    Edited by Jaapkooi
    22 hours ago, PreHack said:
    I read through
    2  Lighting
    5  Bedside Lamp
    7  Wall lamp
    11 Garden Lamp
    23 Dimmer
    Hi Thank you very much.
    Where do you get these value . 2 lichting 5 bedside----------
    edit-  This script works partial (funny you mite say) all lichts go off ( Lichting and Garden) but in the GUI and brouwser of fibaro the gardenlichts stay on.For propertyvalue i had 2, only lichting.
    Edited by Jaapkooi
    Thank you for the deviceControlType  list :)
    Thank you
    Script works fine my problem in the start was my satel alarm . the outputs of the satel are default lichtning (devicecontroltype) I have a lot of links back and forword ,so when i ran the script a lot went on .
    After i changed that it ran great.
    And for others don"t forget you hidden devices.
