variable panel float number error
I have a problem with variable panel. I have enter float number. my number is 336.808 and I can edit this number changed to 336808, i do not add decimal point. Please resize this edit box, is too small.
very thanks
/monthly_2018_10/image.png.9f045ebccbde149b05c6a96d0bdf9866.png" alt="image.png.9f045ebccbde149b05c6a96d0bdf9866.png" />image.png.4669c2680953e6527da07a23f485d582.png
Instead of using variable panel to change value of the global variable you can just use simple line of code to do that. Still I agree that "edit" or display box for variables could be a bit bigger :-)
