Association Flood Sensor
Hi.
Somebody help?
I have problem with association Flood Sensor 1 Group.
I set 1 association group but the Double Switch (1 canal)  switches off only the power supply only after the flooding larm disappears. What's happening? Everything is okay for the stage.
Hi @Novy!,
Fibaro flood sensor sends turn on command when alarm appears. That is why turns off, when alarm stops. Workarround is to use scene.
@T.Konopka, please pass R&D request for firmware update of flood sensor. Possibility to send Turn Off via associations when alarm starts. It hsould not bee that hard to implement reverse logic.
Use-case: Many users use Flow control via Z-Wave (something like
and we need to close valve (need to send turn off command). And as we need reliability even if HC is down, so associations need to be used. It is damage prevention.
Jakub
    Thanks.
    I use this equipment
    cheap and simply.
    Equipped with an electric valve opening / closing actuator. Thanks to the internal limit switches, power consumption is only carried out during opening or closing.
    The device is powered by 220V, additionally has one control cable.
    The application of a "phase" to this conductor opens the valve and the "phase" cut-off from this conductor closes it accordingly.
    Jakub,
    In Fibaro no one will do this for me :)  Forget.
    Regards.
    Edited by Novy!
