xooops 0
Hello
I made the following steps to reset my smoke sensor.
Fibaro Smoke Sensor reset procedure:
1) Make sure the device has the battery installed.
2) Press and hold the B-button for 3 seconds until visual indicator glows white.
3) Short signal will sound.
4) Release the B-button.
5) Wait until the visual indicator glows yellow, signaling entering the 4th menu option.
6) Press the B-button briefly to confirm your choice.
Successful reset will be confirmed with the visual indicator changing colour to red and fading. At the same time, short beep will sound, same as at the power connection.
After 5 the smoke sensor turn off. I don't get an confirmation.
Thanks for your support,
regards, xooops
Edited by xooops4 answers to this question
