Built-in heating panel for heated floor
Hi, everybody!
I am trying to control the heated floor with the built-in thermostat (heating panel).
So, I have a few questions:
1) I can't operate with temperatures higher than 28 degrees in Fibaro App interface and 33 degrees in web-interface. But even 33 degrees is not enough for a heated floor. But lowest temperature I can operate is 4 degrees (even can't imagine how and when such cold temperature can be used).
Why there is the difference with maximum temperatures in App and Web interface take place?
Can Fibaro developers expand the temperature range?
2) Even if they will expand the temperature range, the built-in thermostat is not working. See the video.
What I am doing wrong? Herewith, the Heating panel working well while controlled in web-interface or using the widget.
3) How can Heating Panel mode be changed with the App? I mean Holiday, Manual and Schedule modes.
Thank you!
hi!
you can ask me all question in PM. And maybe I can help you. :)
Welcome.
@cashe
