RGBW as input sensor makes strange things...
Hi there,
i've just got a new front door with motorized lock, not zwave but with digital outputs and clean contacts for opening and closing.
For opening and closing i'm using a double relay (12v dc in) and it works great.
BUT...for reading the digital outputs i've tried to connect a rgbw controller with 4 outputs connected to the 4 IN of the rgbw controller, but i'm finding some strange happenings:
1- the readings are always between 0-10v even if they should stay between 0-5v! and the should be NO...but they're normally at 10v
2- when the outputs are changing voltage (like opening the door), there are some strange happenings in the whole house, lights turning on randomly and blind going up and down...does it make sense for you??
The digital output are give to be "open collector" type, TTL compatible (5v dc) and:
IO max absorbed <= 20 mAdc
VO max at opened collector <= 6 V dc
VO max saturation <= 0,8 V dc
Any ideas??
I'm really bad with basic electronics..
5 answers to this question
    should i better use the Universal Binary Sensor for this application?
    you can as well try to use Qubino 0-10V dimmer or wait until Fibaro Smart Implant is available
    Thanks for attaching this post!
    Qbino I don't want it, it has only one input per module, and Id like to read 3 or 4 inputs...
    Fibaro smart implant...as I can see it will be just like the ubs, isn't it?
    i think you need a resistor to pull the input voltage down.
    i've just tried the ubs for now it looks much better than the rgbw controller...i'm gonna test it a few days
