Motion sensor parameter 3 reverts to default value when saved
I’m trying to make my Fibaro motion sensor eyes to reach on the first breach since I use then very much for light control. How can I make all the sensors react on the first breach?
I’m using HC2 with version 4.510.
Hi :)
By setting parameters 1-4 to suit your needs.
To save:
1) Set all the parameters you want.
2) When all parameters are set, save them.
3) Wake the sensor with 3 quick clicks. or wait for it to wake itself up.
4) Do not set new parameters before the sensor is woken up.
