Hi Guys!
Could you tell me how could I get the real temperature value (not the target ) from Danfoss RS room thermostat?
I also have problem with the DANFOSS valves. Is there any feedback from that state is it open or close,  the real temperature value or something that I can use.
Thank you in advance,
fibaro:getValue(deviceID, "value")
will give you the actual value ( temperature)
About the Danfoss valves: you can not get feedback about the valve opening , nor the current temperature. Only the set temperature can be obtained.
    Hi Momos.
    Thankx for your answer. Unfortunatelly in this case I get the target tempereture.
