Configuration of the thermostat kit Secure SRT321/SSR303
Hello! I have the following situation and can not find the solution: a boiler with a pressure equalizing cylinder (with a pump in the primary circuit), three pumps (the secondary circuit), two pumps for the ground and floor and the pump no. three for a storage of domestic water. I want to order the two pumps with two thermostats (SRT321) and two receivers (SSR303), both connected to a HC2 controller, a ground-level thermostat and a first-floor thermostat. If I go to the heating panel and modify the temperature, the receiver reacts well, but the thermostat does not update the status (it's the icon on the "flame" display) and I do not know when the relay is on or off (maybe if I go to the room the technique and I see the green or red light). I think there is something wrong and I do not know how to do it, I want that when the state of the relay (receiver) that is controlled by the heating panel changes, to update the status on the display to the receiver, also if I rotate the disk by setting the desired temperature, update also in system (HC2). Thanks and apology for language!
