My First scene - Don't work as i expected
Hello!
I try to start learning Lua to create Nice Scene!
I can do 3 Different Scenes in Graphic to realize my idea.
But i wish do ONE with LUA Programing..
I don't have any errors, if i press button PLAY all is fine, But it work only once.
Can you please look my code and tel what i must do that this scene will be Loop.
THANKS, FOR HELP!
ILJA.
-- Set All Outside Light to 1 % - Not Veranda Becose veranda is ON by user
if (
    fibaro:getGlobalValue("DayLight_Status") == "Dark"  and
    fibaro:getGlobalValue("Day_Status") == "Night"  and
    fibaro:getGlobalValue("Outside_Front") == "OFF"  and
    fibaro:getGlobalValue("Outside_Light") ~= "Night"  and
    fibaro:getGlobalValue("VerandaLight") == "On" ) then
      fibaro:call(227, "setValue", "1");
    fibaro:call(228, "setValue", "1");
    fibaro:call(229, "setValue", "1");
-- Set All Outside Light to 1 % Becouse is to late and we save energy:)
elseif (
    fibaro:getGlobalValue("VerandaLight") == "Off" ) then
    fibaro:call(226, "setValue", "1");
    fibaro:setGlobal("Outside_Light", "Night");
-- Set All Outside Light to 8 % Evening light.
elseif (
    fibaro:getGlobalValue("Day_Status") == "Day"  and
    fibaro:getGlobalValue("Outside_Light") ~= "Evening" )
      then
    fibaro:call(226, "setValue", "8");
      fibaro:call(227, "setValue", "8");
    fibaro:call(228, "setValue", "8");
    fibaro:call(229, "setValue", "8");
    fibaro:setGlobal("Outside_Light", "Evening");
7 answers to this question
only from second if run.
For information:
  • if fibaro:countScenes() > 1 then fibaro:abort(); will kill every NEW instance of the scene and keep the first instance running.
  • parameter "%% killOtherInstances" at begging of scene code will kill all PREVIOUS started instances of a scene and the NEWEST instance will go through.
Take decision run your code in loop or triggered if any of checked in code variables are changed.
For loop:
For triggering method (preferred by looking resource):
 I wrote the code quickly and I couldn't test it now on HC2 but I think it's ok.
    Thanks for help.
    Can you help me once again.
    I was found way how run it loop
    if (startSource["type"] == "autostart") then
     while true do
        fibaro:sleep(1*1000)
    Is this wrong?
    It's work few days, and I'm Happy but question how it load System?
    If i will have 10-20 Scenes like this.
    THANKS!
    Edited by Ilja
    Yes it's ok. For load the system, the question is number of VD's with code in main-loop and scenes running continuously and simultaneously.
    A few simple scenes like this one doesn't use many recurse.
    I things is good that you add code for kill instance if run more that one. This happens sometimes (HC2 can do it). In your loop add:
    Thanks again, yes i will add
    But this will kill all processes or only from second?
    THANKS, FOR HELP!
    no problem, good luck with LUA, there are a lot of helpful people on the forum so it will be easier to start
