Sometimes, scene wont turn plug ON/OFF
Hello guys,
I created a simple scene to turn on and off the plug at exact time. Problem is, sometimes the scene is not working and it wont turn the plug on or off.  RAM status is about 75-80% with Fibaro HCL.
Anyway, i noticed that not always is there a 1 istance running, and, as i know, if the scene has a time variable, there should be always one instance running.
(Pak = Then; V přesný čas = at exact time; vypnout = turn off)
/monthly_2018_11/487395885_4692579912486748686(1).png.b808eaaa88352a58326396b7e6fbbf8c.png" alt="487395885_4692579912486748686(1).png.b808eaaa88352a58326396b7e6fbbf8c.png" />
Hi
Yes, you should always run an instance, try a restart.
There must be marking in run when hc2 runs.
Also try a delay of for example 8 seconds in the box where zero is now.  :)
    This option is checked. I will try to put there a some valuable for countdown to see if it solve the problem, but with this change, the number of running instances will change to two, or not?
