Motion sensor fibaro not add to the home center 2
xXxTRO
Hello, I can not connect my motion sensor to the home center 2. when I press 3 times the b button turns on a blue light on the sensor but does not add to the home center 2. can you help me in any way?
I  have had this issue. I fixed it by going to remove device on HC2 and pressing button three times. This removed device ( even  though on installing device, blue light seemed to indicated device installing and HC2 claiming installation was complete but device did not appear on system and subsequent install attempts did the same ) . Then I installed device and it added device correctly instead of the HC2 indicating it completed installation but no info scrolled on screen. It must indicate all data values accepted or device will did not show up any where in system correctly.
  • Thanks for the reply. I tried to remove the device from the hc2 but it is not removed. the removal is not confirmed to me,
    Device is ether partly installed or hidden on system or remove process was not carried out correctly.
    My sensor at one stage showed partially installed  but next time no sign of it on system.
    Removal only confirmed device was removed after asking for press of button on device to be removed.
    If battery is installed wrongly or weak or device too far from HC2  could cause issues.
    Last suggestion systematically check all mentioned items and try again.
    I fixed this issue this way. Good luck.
    End.
