Scene with double condition
Hi everyone,
I've a Fibaro HCL with 4.170 firmware and I would like to create a scene that turn on my wall plug (water heater) if there are this 2 condition:
  • specific hour and days of week (working days at 6:00 am);
  • my door sensor is disarmed (I'm at my home).
I try this scene with a global variable (in or out from home) and with armed or disarmed sensor in the condition, but the result is the same: when I disarm door sensor the wall plug turns on without considering the day and the time.
Can someone suggest me how to correctly write this scene?
Please remember that I have a HCL, so no LUA code please..
4 answers to this question
You could use the ''and'' condition at the beginning
Also adding a turn device off after a specific time changing the value of 0 s to lets say 1 hour = 60 minutes x 60 seconds = 3600s
Edited by Axeman
When you use time as the first condition in your scene and then check for variable your scene will work if you uncheck the variable as a trigger for your scene ( the trigger is above the blocks in your scene).
    This is my scene and I try these in several way, but when I disarm my sensor the scene start. Can anyone help me?
    /monthly_2018_11/Capture.JPG.cbef928d6acbfa4cc25fc3b081b61219.JPG" alt="Capture.JPG.cbef928d6acbfa4cc25fc3b081b61219.JPG" />
