Bpm 0
Where to put into the code %% killOtherInstances ?
My motion sensor generates more instances by detecting movement, I´d like to kill older instances by this
below is lua code for turning off wall plug when motion sensor is safe 30 seconds…
Ive putted it on the beggining it doesnt works
%% properties
21 value
%% weather
%% events
%% globals
if(startSource["type"] == "other") then
fibaro:call(8, "turnOff");
else
if (( tonumber(fibaro:getValue(21, "value")) == 0 )) then
setTimeout(function()
local delayedCheck0 = false;
local tempDeviceState0, deviceLastModification0 = fibaro:get(21, "value");
if (( tonumber(fibaro:getValue(21, "value")) == 0 ) and (os.time() - deviceLastModification0) >= 30) then
delayedCheck0 = true;
if (
( delayedCheck0 == true )
or
then
end, 30000)
12 answers to this question
