503 error and my workaround proposition
Hey Fibaro.
sometimes my HC2 got 503. It’s ok (bad word here) when I at home = reboot 50/50 recovering mode - skip =HC2  online
but when my family and I for example on holiday trip etc?
yes, I can configure for example Zabbix for checking HC2 or simple crontab curl polling and chasing Http return Coee
but, what I can do for rebooting HC2? Yes, nothing! HC2 http web endpoint is dead., SSH port closed , home is totally “naked” and uncontrolled .its pain!
Thnak you!
so,
1st question can you up another nginx site (independed) for listen reboot command?!
2nd can you create own Crontab event for checking !200 htttp status code and reboot HC2
ps: Holidays are coming. Holidays are coming (c)
6 answers to this question
R u serious about it? Why dont u ask fibaro to make stable firmware instead of?
Without stable hub, home automation become a toy.
50 minutes ago, 10der said:
SSH port closed
Didnt knew the SSH is dead on 503. Are you sure about it?
@jack.daniels, how do you manage to have LUA when you have HCL?
Have to install a mod using custom recovery.
Hi, I have put the fibaro thermostat in standby mode few days ago.
There was NO 503 or ANR since that time.
Is it ok for a workaround? ;)
    lil!
