Dimmer 2 with illuminated push-buttons (Busch Jaeger 2020 USGL)
I'm trying to get the dimmer 2 working together with the Busch Jaeger 2020 USGL with illuminated push-buttons.
Without the dimmer 2 the push buttons on the switch are illuminated when not pushed in.
When I place the dimmer 2 in the circuit I can control the lights like supposed to but the buttons aren't illuminated anymore. Anyone got an idea how I can get those illuminated?
I've tried both wiring diagram 1 & 2 (Single Switch)
Link to push-switch:
According to
 there are different wiring options, see section Wiring diagram.
The one to the right should illuminate the button always, even with a fibaro module in between. Only drawback is, that the button will be illuminated even when the light is on.
Unfortunately I was not able to find a more detailed manual, but probably this helps already.
