julesmartens 0
Hi @AutoFrank
I installed the message hub V1.2 and LAN Monitor VD 2.6. (All reported online).
Note that I removed Sonos internet check as unfortunately I do not own a Sonos system ;-(.
In messagehub I set my users/email id's, my JSON table, my API for PushOver.
See below dump of the user setting section of the scene.
Note that I replaced my API by "X"and "Y" for public sharing.
BTW I did not load the demo VD.
When I run the message Hub I get a error;
[DEBUG] 17:08:08: [1;31m2018-11-20 17:08:08.834065 [ error] API: Not found
[DEBUG] 17:08:08: main function triggered
Any Idea why I get this error?
Regards
Jules
DUMP
-- ** USER CONFIGURATIONS & SETTINGS ** --
-- * OPTIONS FOR SMART RE-ROUTING OF MESSAGES * --
-- Set to true to enables re-routing of sonos TTS messages to HC2Popup
-- notifications if the sonos-http-api or Internet is unavailable/offline
-- to your local LAN
local tts2popup = "false"
-- Set to true to enable Sonos TTS messages to queue when
-- presentState = 'Away' When presentState is set to Home it triggers
-- the scene automatically and unloads the message in the TTS queue
-- to the default player that is configured
-- below
local tts2queue = "false"
-- Enable for NO TTS announcement in sleepState, TTS announcements are
-- NOT queued
local tts2sleep = "false"
-- Enable a Delay before TTS announcements are unloaded (seconds).
-- Leave as "" for no delay
local ttsUnloadDelay = "30" -- seconds
-- Set to true to enable all notifications to re-route to HC2Popup
-- notifications if the internet is unavailable/offline to your local LAN
local notify2popup = "true"
-- Set to true to enable all notifications to queue when presentState= 'Away'
-- When presentState is set to Home it triggers the scene automatically and
-- unloads the message in the notifications queue to the default notification
-- service that has been configured below
local notify2queue = "true"
-- * OPTIONS TO MONITOR THE INTERNET STATUS * --
-- This provides 3 options to monitor the availability of the internet and
-- sonos-http-api and anables the notifications to Queue function to operate
local ipMonitor = "networkTable"
-- Select 'manual' if you wish them to be permanently set to online. Please
-- note that this option does NOT enable queuing of notification messages.
-- Select 'networkTable' to leverage the LAN Monitor VD v2.5 or VD v2.6,
-- Select 'wwwapiTable' to leverage the new simplified WWWAPI Monitor 1.0
-- * HC2 EMAIL CONFIGURATION * --
-- List all users that you want to be able send messages to. The user id's
-- are located in the HC2. Select Configuration, then Access Control to
-- see the current users.
hc2emailUsers = {["jules"]="71", ["vannessa"]="164"}
-- * HC2 PUSH CONFIGURATION * --
-- List all users that you want to be able send push messages to. The mobile
-- devices ID can be found by going to http://<HC_IP>/docs/ under iosDevices
-- section.
hc2pushUsers = {["iPadvanJJD"]="336", ["OnePlusONEPLUSA501"]="286", ["IPAD128gb"]="218", ["iPodVannessa"]="219", ["iPhonevanVannessa"]="216"}
-- Select a default user from this list and this is used if there is
-- no user specified as part of the message invocation
local defhc2pushUser = "71" -- identify default hc2push user
-- * TTS PREFERENCES * --
-- Select your TTS preference. If you use the sonos-http-api solution please
-- enter API. If you use the Sonos VD Remote solution please enter REM.
local ttsMethod = "REM"
-- Ths allows you to select a default volume. This volume can be changed by
-- including a different volume in the message invocation
local defTTSvolume = "40"
-- * SONOS-API PREFERENCES * --
-- List all the sonos players you want to send TTS messages to. The names
-- must match exactly what is on your sonos native app. The default
-- player is uder to unload the TTS message when presentState is set to Home.
-- The ip address and port are of the device that is hosting the sonos-api
-- the last item is the language or voice code for the respective TTS service
APIplayers = {"hallway","kitchen","livingroom","diningroom", "playroom","garage","bed5_office","bed_le","bed_frank","bed_masterl","bed_guests","landing", "pizzabbq_area"}
local APIipaddress = "192.168.1.89"
local APIport = "5005"
local defAPIzone = "kitchen"
local defAPIlanguage = "Amy"
-- * SONOS REMOTE VD PREFERENCES * --
-- List all the sonos player virtual devices you want to send TTS messages
-- to. The vd id's match exactly what is on your HC2. The default
-- The last item is the language or voice code for the respective TTS service--
-- The format is as follows
REMplayers = {
["dnevni"] = {vd="334", btn="28"},
["soba"] = {vd="335", btn="28"},
local defREMvd = "hall"
local defREMlanguage = "en-gb"
-- * DEFAULT TITLES AND SUBTITLES * --
-- Adjust the default titles and subtitles. If no title or subtitle is included
-- in the message invocation then the default values entered here will be used
local defTitle = "Alert Title" -- Default title for notifications
local defSubtitle = "Alert Subtitle" -- Default subtitle for Popup Service
-- Default popup message type, possible values: Success, Info, Warning,
-- Critical
local defPopType = "Info"
-- please define popup message default button caption
local defPopCaption = "OK"
local defPopButton = { { caption = defPopCaption, sceneId = 0 }}
-- Refer to Sankotronic Tutorial "Popup Notifications and Custom Images"
-- for format and examples
-- * NOTIFICATION SERVICES * --
-- Select the default notification service that you wish to use. This default
-- service will be used if no service is invoked in the message and is also
-- used as the service to unload the queued messages when presentState is
-- set to Home
local defmessageSvc = "pushover"
-- * PUSHOVER CONFIGURATION * --
-- Enter the respective pushover notification details below if you wish to
-- use this as a message service. You will need to regfister at pushover.org
-- and follow the instructions. All 4 pieces of inforamtion is required
local POtkn = "X"
local POusr = "Y"
local POdevice = "ipad, Iphone-vannessa, Ipod, OnePlus5t"
local POpriority = "0"
-- * TELEGRAM CONFIGURATION * -- (see telegram.org)
-- Enter the respective telegram notification details below if you wish to
-- use this as a message service. You will need to regfister at telegram.org
-- and follow the instructions. Both pieces of inforamtion is required
local TGtoken = ""
local TGchatID = ""
-- * DEBUG VERBOSITY OPTIONS * --
-- This allows you to observse extra information in the debug window when
-- the scene is running.
-- deBugVar will display the scene variables
-- deBugCfg will display the scene configaution that you have set
local deBugVar = true
local deBugCfg = false
-- "PresentState" is predefined global value that determines if you are at home
-- or away. This variable value is set by other scene or VD. Enter name of your
-- global variable between "" if called different or leave as it is
local presentState = "PresentState";
-- Enter corresponding values that you use for presence in your language. Change
-- the one in quotes or leave as it is
local presentStateMapping = {Home="Home", Away="Away", Holiday="Holiday"};
-- "SleepState" is predefined global variable with possible values:
-- "Sleep", "Awake".
local sleepState = "SleepState";
local sleepStateMapping = {Sleep="Sleep", Awake="Awake"};
-- Please amend the text sent to PopUp Notification when Internet or TTS is
-- offline to your own language if you wish
-- Title and subtitle can be modified
local TTSofflineTitle = "Announcement"
local TTSofflineSubtitle = "TTS is offline, TTS announcement sent as popup notification"
local WWWofflineSubtitle = "Internet is offline, TTS announcement sent as popup notification"
-- ** HOMETABLE ** is a global variable used to store HC2 device and scene id's
-- Uncomment next line if you wish to use Hometable data in scene
local jT = json.decode(fibaro:getGlobalValue("HomeTable"));
