How to access Fibaro Lite from remote computer?.
I can access Fibaro lite from mobile but can not recall if I can do from my Mac as IP address should be different. Any Fibaro portal I can access then link back to my unit at home?
If I understood you right, you would like to log in to your HCL from your Mac when you're home.
Open the web browser and enter the IP number of your HCL. Use Fibaro Finder if you do not know which IP number your HCL has.
To log in to your HCL from an external computer:
Log in first with your Fibaro ID, then log in to your HCL with your local user information.
    What I mean is, from Mac Computer far away from my home. Your 2nd paragraph did answer this. Thanks RH_Dreambox!.
