Minimum wire gauge for Dimmer 2 switch
What is the smallest gauge wire that can be used to connect the on/off switch to the Dimmer 2? The reason is that there's not a lot of extra room to insert a #14 gauge wire into the Sx terminal and a second wire from the N terminal going into the Sx terminal when wiring up for a two wire installation.
    The switch has a very low voltage across it. While controlling 120VAC lamp with the Fibaro Dimmer 2, I measured only 0.03VAC across the control switch.
