Weather not updated on the HC2 home page
Since a couple of weeks the weather information is no longer updated: temperature stays 11°c,  humidity = 91% etc.
On the settings i have as weather provider 'YR Weather' (my selection since the start) which is the only option i can select.
Anyone an indea what i can do to get back actual weather info?
Roland
Hi
I have installed the yahoo weather plugin and selected this  and it works.
Problem partially solved as the advertised temperature is not really correct. It shows 4°c while it is actually 7°c outside!
Anyone an idea how frequent this gets updated?
Regards
Roland
Edited by Roland declerck
see:
Select the correct weather provider in Settings.
If it does not help, delete the device and reinstall the YR Weather plugin.
It worked for me.
Another issue has come back as well: a change in weather conditions does not trigger block scenes any more!! I thought this was solved but now it has come back again.... :-(
Hopefully this will be solved rather sooner than later!!
Edited by Ulf100
