Splinter 0
Hello
Who knows who with the radiator?
Here is the Fibaror radiator advertised really professional.
Unfortunately, there is no guide on how to fully use the radiator with all its capabilities.
1)
The FIBARO Heat Controller scans the room environment at the beginning and learns from the collected information. So he can react to the appropriate conditions. Intelligent heating management is provided by specially developed algorithms.
Then there are so great Dineg like:
18 min to listen for temperature x ...
How can I retrieve this information?
2)
Work at a specific place and time *
There are rooms that you do not necessarily use every day: a guest room, the gym or the office. Thanks to the adjustment operating mode, the FIBARO Heat Controller lowers the temperatures in selected rooms, resulting in energy savings. As soon as the FIBARO Motion Sensor detects a movement in a room, the temperature is brought to an optimal level; a really advanced solution.
Does this happen automatically?
Just a motion in the room and the heating regulates high without the heating plan being considered?
3)
Precise temperature measurement
The radiator thermostat can use an additional built-in temperature sensor4. You can decide for yourself where the measurement should be performed. In this way, excessive or insufficient heating can be avoided. The temperature should always be perfect in the right place!
Does that mean that if the room say I have 20 degrees and I have set a temperature of 19 degrees in the heating plan, the heater is not gra s first?
4)
Always ready for your voice command
Do not you feel like getting up from the couch or reaching for your cell phone? Control the temperature with your voice! This convenient feature is accessible both in the FIBARO system and on the HomeKit platform or via a different voice interface.
Can someone tell me how Alexa can control the heating? Did I miss something that happens all at once?
You get room temperatures announced and can set the heating by Sparche to the desired room temperature?
5)
Automatic calibration
The FIBARO thermostatic head is easy to install, self-calibrate, and easy to control for proper connection. To achieve precise control precision of the water flow, the FIBARO head controls the distance and adjusts it to the working area of the needle. This will allow you to be sure that the installation has been carried out correctly and that the system can be put into operation without any problems.
Where can I find this function?
Many Thanks.
4 answers to this question
